Can I transfer NMS License from one server to another?
Hello, I would like to know if it's possible to transfer an NMS-BASE-25 license from the current installed server to another server? If yes, what is the procedure? Thank you.
Hi, i have EMC 8.1.1.41 and x440G2-48p-10G4 (in stack) XOS:22.3.1.4 -patch1-4 with External Power Supply (STK-RPS-1005PS). Problems: 1. Missing Power Supply Status in EMC (Network->Devices->Switch->Power and Fan Status) 2. No Warning or No Error if ...
How can I change the port number op the open device terminal ? Now I got an error: Failed to connect
Hello, We use Extremen Mangement Center (Netsight) for nearly all customer situations and enjoy the multi-vendor solution. But one customer is very frustrated by the small impact he gets in his Cisco environment. The installed version of Netsight i...
Hello, I Would like to find out about the above, specifically i would like to know how many Reach NXT devices we have on the network without having to display lldp info from each switch. I'm sure back in the day Extremes old management platform, Ep...
| User | Count |
| 102 | |
| 101 | |
| 42 | |
| 19 | |
| 17 |
