How to upgrade EXOS in multiple Swtiches Simultaneously
How to upgrade EXOS image in more than 40 number of X440-G2 switches simultaneously. Please share the procedure to install EXOS image simultaneously. Thanks in advance.
I need to login to a switch, run a 'show' command, then save the output to a file. I need to do this for 30+ switches, and would preferably like to save the output of each switch's show command to a filename matching it's hostname (SwitchA output to ...
Hello, I need some guidance on upgrading our Netsight server. We have an older Dell sever (64-bit, 4gb ram, 250gbhdd) running Netsight 6.3.0.174. We have on order two C35's to replace our C25's and we are adding about 40 more AP's. We have a capti...
how can i create a report about NAC Guest access (wired) where i can see the GuestClient information and his sponsor. We are using NetSight Suite V7.1.1.9. The predefined NAC Reports doesent give me this information. Is there any way except exporting...
I need to report on which VLANs are associated with switch ports. I want to be able to navigate to a particular switch and discover which VLANs are assigned to which ports. I need to see this in some kind of inventory/report format, not via CLI comma...
| User | Count |
| 102 | |
| 101 | |
| 42 | |
| 19 | |
| 17 |
