AAA[1450]: Login failed for user admin through xml
Hioes anyone have an idea as to which part of Netsight generates the above error on an Xos switch
After a NetSight upgrade to 7.0.8.34 we don't see the End System list, but wireless clients auth is still working. The netsight.tam_endsystem mysql tables contains only the previous upgrade records. Thank you for your help!
Hello, everyone! I want to configure Identity Management. Now it works only with Kerberos option configured. The result is only for 10% of ports in the stack I can see hostnames, domain name, IP and very rare - username. I wanted to configure LDAP ...
As far as I've read a lot of browser will end the support for SHA1 certifcates next year. Is there a official document / warning which products are affected and how to generate SHA2 certificates. I.e. how could I change the factory installed self s...
Hi. We need to change all switch's password, but to config it manually, it take too much time. So can we change it all via Netsight ? If can, what is steps ? Thanks.
| User | Count |
| 105 | |
| 102 | |
| 44 | |
| 19 | |
| 17 |
