Has anybody got RADIUS auth. working with Ubiquiti UniFi APs and Extreme NAC?
We're testing Ubiquiti UniFi APs and I'd like to be able to use our Extreme NAC devices for RADIUS instead of building a new server. Has anybody tried this before?
I have a new setup of purview and sensor. All configuration for sensor and Purview tunnel is well done. The purview report to netsight as it is shown in status-diagnostics. as well as the browser show some for applications, But the reports dashboard...
How do I create and use a configuration template using Management Center (not the legacy application called Inventory Manager)? I have a newly configured switch which configuration I want to use to create a template to apply to new switches. Even t...
My goal here is to get consolidated wireless stats for a building: the library. The library has two floors, and the access points are broadcasting I think 3 or so SSIDs. The specific information I want is guest usage. The problem I'm running into...
Hi all Can anyone tell me where the option to rma a device is in oneview/netsight. I know it is on a tab, but i have spent a hour looking for it. Or was i dreaming?
| User | Count |
| 105 | |
| 102 | |
| 44 | |
| 19 | |
| 17 |
