Use netsigt to restore backup configuration
We need to send a backup config to a switch , currently not on site , though trying to help out a fellow engineer. The config has been backed up to Netsight.. Many thanks
Hello, I'm trying to setup useful alarms in netsight for DCS threshold events. Currently we have a very basic alarm setup that triggers when custom string "DCS Measured Noise" and "Exceeded Threshold of" are matched. These are syslog events source...
I am trying to create a flexview that contains the IP address, Model #, Serial #, Manufacture date, location, switch type and slot id. I have successfully gotten the all of the columns except for the slot ID to work. I have tried to use entPhysicalDe...
Hi everyone, We are currently planning an upgrade on all of our network switches mostly x350's / x450's with firmware 12.6.5.2 and a couple of x650's in stack, as our cores, with firmware 12.3.4.12. The main administration wants to rely on...
Error setting port data for device - When create any configuration on POLICY MANAGER, when apply this error appear with any model of device (D2,B5,C5)
| User | Count |
| 105 | |
| 102 | |
| 44 | |
| 19 | |
| 17 |
