Using NAC to drop traffic based on a schedule for a specific VNS
I need to drop traffic based on time and location. What is the proper way to create the rule in NAC? Time is 6p-6a weekday, and 24 hours Sat and Sun.
Is it possible to pass on 802.1x user credentials to an iBoss filter from the wireless controller using an NPS server for radius auth, or do we need to use the NAC as the radius server? We are trying to avoid using NAC if possible, but would like to...
I've added three X440 switches to my new installation of Management Center. I am in full control of them with SNMP and CLI credentials. Management Center successfully backs up their configurations. When I select one of the switches to upgrade fi...
Hello, Is there a rule to calculate required datarate to successfully poll end-systems data, events etc. from NAC GW to NMS or do you have some example values measured? I have an opportunity where NAC GWs are to be installed in remote locatio...
I want to test a client running Analitys NetSight but my license does not allow me, as I generate a Demo license. I also want to know whether the sFlow of Extreme switches can be monitored with this function on NetSight? Thanks for your help and re...
| User | Count |
| 102 | |
| 101 | |
| 42 | |
| 19 | |
| 17 |
