how to add port groups to Eaps Domain in Netsight ?
In Ridgeline you would create port groups and associate those port groups to a defined Eaps Domain and run a script to add a new vlan to those ports. How would you perform this in Netsight 6.3 ?
Dear all. I need your help here. We have two identical devices which services one application. 2x G3-Series with 6.61.xxx Switch-A - active node - server are connected at this device with a single link Switch-B - hot standby if D...
The Extreme switch X440 PoE fail always without error log. When the PoE fail, CLI "show inline-power info" will return timeout. Can I using the Netsight to notice me that the inline-power is fail? And how to create the alarm when the port without inl...
Hi! I'm trying to get OneView report showing me end-systems I were not aware of, that e.g. have Unregistered NAC Profile. On OneView End-Systems section I can choose relevant profile from the Dashboard circle graph, and then I see only such end-syst...
I use to be able to see a list of ports and then get more info on the port status, throughput over time etc... It's been missing for a while now.
| User | Count |
| 105 | |
| 102 | |
| 44 | |
| 19 | |
| 17 |
