Where to find Apps expiration Time?
Hi!! does anyone know where can i check the expiration time of my appliances?? what kind of "thing" expires in appliances? Support? guaranty?
Hello together, I have a problem with backing up configs using NetSight 6.1. We have a lot of devices running Extremeware 7.8e2 (Summit 200-48, Summit 400-48 and so on). The rest of our Devices are running on XOS 15.3.1.4-patch1-41. Both Versions a...
Hi together, i want to use Kerberos Snooping for the authentification of my clients against nac appliance. The Access Switch is an Enterasys B5 Switch. Is it possible with that switch or do i need a switch which supports Kerberos snooping? I have tr...
Hi, All I can't upgrade EWC(V2110) firmware by Inventory Manager, but i can download configuration file from EWC to NetSight. How can i do?
Applying a WLAN to WAPs, I have set up a new SIDD and want to assign it to several WAP how do i do this ?
| User | Count |
| 102 | |
| 101 | |
| 44 | |
| 19 | |
| 17 |
