Hello,
The problem looks to be that the relevant information isn't brought into the configuration evaluation tool when it is used in the web GUI.
In the Java GUI:
If you type in the "SSID" or relevant information the configuration evaluation tool seems to select the right role.
For location based "Wireless" rules the "Switch Port" field is not used for criteria matching.
Thanks
-Ryan
