EXOS: Setting port speed and duplex via Netsight tools
M_Nees
Contributor III
Whats is the suggested way if a customer wants to define port speed (maybe reduce gigabit switch ports to 100MBit because of bad cabling or other reasons) with graphical tools of netsight - like console or oneview.
My customer wants to do this on X440 (G1) and X440-G2 Switches with current 16.1.x. firmware. Netsight V7.0.
in oneview i do not find a way to do this ?! Is this currently not possible ?
in Netsight Console (Properties - Ports) i can set the "speed admin" and "duplex admin" field and write it but the client anyway used gigabit speed.
Whats is going wrong here ?
5 REPLIES 5
Ronald_Dvorak
Honored Contributor
Hi Matthias,
you need to disable auto-neg if you want to use the static speed/duplex values,
Cheers,
Ron
