Management Center Installation Requirements
Paul
New Contributor III
When reading the Management Center installation guide it mentions the server requirements for small, large and enterprise installations. I assume this is referring to the number of devices being managed but there is no indication of the limitation of each installation. Can anyone shed some light on this?
Also, are different licenses required for each of these levels?
7 REPLIES 7
Bin
Hello Paul,
There is one script which will you help to understand NMS license.
NetSight license - What options do I have for NetSight?
https://gtacknowledge.extremenetworks.com/articles/Q_A/What-options-do-I-have-for-NetSight
Thanks,
Bin
Ryan_Yacobucci
Yep,
Licensing will dictate number of devices and what feature sets are unlocked. (NMS-BASE, NMS, NMS-ADV)
Thanks
-Ryan
Paul
New Contributor III
So the level is just a guidance for number of devices likely to managed and the device count licensing dictates the number of devices?
Ryan_Yacobucci
Just to add to this regarding licensing.
Licenses also comes with a managed device count, so if you have 100 managed devices you could install and configure for "Enterprise" level and still have an NMS-100 type license.
So licensing is independent from server size.
Thanks
-Ryan
