NAC portal - different features/options
‎12-04-2015 12:41 PM
Hi, is there a document/matrix available that explain in short what the different features/options do.
i.e.
feature1/option1 = guest client get web portal and just has to provide a name to get access
feature2/option2 = guest client get web portal and needs username/pw which is provided from sponsor
I've a hard time in every installation to get the right one as in my opinion the description is very cryptic.
i.e. which one is the right if I like to have a open/none SSID with a portal that requires username/pw from a sponsor... no clue...
Thx,
Ron
i.e.
Thx,
Ron
6 REPLIES 6
‎06-19-2017 05:29 PM
‎02-16-2017 07:23 PM
i agree with Ron - i have to read the explanation twice or more to understand the difference between the several modes (because the title and explantions are not easy to keep in mind) ...
Regards,
Matthias
Regards,
Matthias
‎02-16-2017 01:55 PM
Hello all,
for me, this explanation would also be very valuable and I think this should be self-evident.
Regards
Stephan
Regards
Stephan
Regards
Stephan
‎02-15-2017 04:22 PM
What's the status on that - I can't even find the ticket in my case view.
