NAC unlicensed after upgrade to 8.4.3.24
Ralf
New Contributor II
Hello,
we have three virtual Access Control Engines: two with a NAC-V-20-License and the third was licensed by our NMS Advanced license.
After upgrade to 8.4.3.24 today, the Engine uses the NMS Advanced license shows as unlicensed and I can´t Enforce it.
Has anyone an idea? I started the Java client, same issue.
Thanks in advance.
Kind regards, Ralf
1 ACCEPTED SOLUTION
Ryan_Yacobucci
The NMS Advanced Bundle will be the most precedent license on the list and will be used to attempt to license the NAC appliances. You get a 90 day grace period after upgrade to upgrade the license, which is in line with the expires date for the license.
You should also remove the Advanced Bundle and NMS Bundle licenses. Licenses are not additive so they’re really just making things more confusing at this point.
Once upgraded see if the NAC’s license themselves, if they don’t click on the NAC → Details → click the “Update license” link.
If a prompt does appear please read it thoroughly. I believe it asks “Do you want to use a license other than the NMS license applied to the system”. In this case you want to hit “no”, because you want to use the applied license.
Thanks
-Ryan
7 REPLIES 7
Ralf
New Contributor II
Thank you for your idea, but the reboot of the NAC and the NMS didn´t help.
Regards, Ralf
Ryan_Yacobucci
Hello,
What version did you move from and to?
You may need to upgrade the XMC license. If you go Administration → Diagnostics → Server → Server Licenses does you license no longer show as permanent?
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-upgrade-a-NetSight-license-for-use-...
Thanks
-Ryan
PeterK
Contributor III
I had same issue 2 week ago.
After rebooting NACs and NMS I was able to update NAC license.
