NeSight Console - Using Command Script Tool
‎07-25-2014 06:05 PM
To use Command Script Tool is necessary to configure a username and password in NetSight Authorization/Device Access and Profiles/Credentials-->CLI Credentials.
How can I to hidden my password on CLI Credentials to that another person don't see it?
6 REPLIES 6
‎07-25-2014 06:52 PM
You need to add different "Authorization Groups".
i.e. I'm in the group "Netsight Admin" and could access every menu within Netsight but I've created a user group "NOC" with restricted access.
So you could restrict the group NOC so they can't access the authorization/device access menu to access the password but could allow them to use the command script tool.
Here what they get if they try to access the authoization/device access menu...
-you could add a new group in > authorization/device access
- the command script capabilities could be found in > Netsight Suite > Devices > Execute Command Script
‎07-25-2014 06:21 PM
I am not aware of this procedure but you can always create a default one that everyone can use when using the command script. If this is used just for collecting data.
I would suggest trying this as a client machine (rather than doing from the server machine) to see if that works but I am not sure that this can be done that way
