Scheduler do not updated
Visconti
New Contributor III
In my netsight 8.1.6.20 the Log tab SCHEDULER does not update
In fact it is stopped in 14 feb 2019 despite having verified events to be detected such as the backup of the scheduled system every week.
does anyone know how to resolve this problem ?
1 ACCEPTED SOLUTION
Ronald_Dvorak
Honored Contributor
With system you mean the XMC database backup - if that is the case you'd find it in the Java UI in the Console tab or the Web GUI as per the below example...
7 REPLIES 7
Ronald_Dvorak
Honored Contributor
The log info for archive backups should be in the inventory tab and not in the scheduler tab.
Visconti
New Contributor III
Yes but the result is the same...I forced a scheduled backup but the windows is stopped at the previeview attached above
Ronald_Dvorak
Honored Contributor
Have you tried a restart of XMC ?!
-Ron
