a month ago
Was able to ping the SE --server from the switch (logged via ssh) .Tried to ping the switch from the SE but shows as not reachable.
Task:---To get attached to SE and perform automatic backup(archive) and firmware updation scheduled for a number of universal switches --5320/5420 Fa running on 8.9.0.0 (VOSS)
switches running on BOSS and VOSS exclusively are working fine without any issue but the ones of universal switches(which has the ability to be configured as Exos or Voss) is the main problem.
Any help or support is appreciated alot. Thanks in advance.
Solved! Go to Solution.
3 weeks ago
Was able to figure out the problem was indeed with the SFTP configuration defined in inventory-manager (at Site Engine)and the access-policy defined at the switch end.
3 weeks ago
a month ago
I would upgrade XIQ Site Engine first to 23.11 or 24.2 and check after that.
a month ago
Ping issue has been resolved able to figure out that firewall was blocking the outflow traffic from the switch. Although devices are reachable, bidirectional traffic flow is available still from the webshell it shows connection closed. I believe that would be the starting point to proceed ahead with the further archieve/firmware etc..
Below snapshot does trigger anything much???
and the site engine version is as per below snapshot...
a month ago
What version of XIQ Site Engine ? Are you archiving through ssh/scp ? If your Site Engine is too old it could be a cipher issue, or your scp settings could be wrong. https://extreme-networks.my.site.com/ExtrArticleDetail?an=000111555
