Unable to upgrade firmware in Management Center on a single switch
Jesse_Ohlsson
New Contributor II
I've added three X440 switches to my new installation of Management Center. I am in full control of them with SNMP and CLI credentials. Management Center successfully backs up their configurations.
07a5bee69e9342a6b69e7cc18b9d37c9_RackMultipart20160729-120239-14vfng8-3_switches_inline.jpg
When I select one of the switches to upgrade firmware (I know, they are already on the latest version), I get the normal dialog window:
07a5bee69e9342a6b69e7cc18b9d37c9_RackMultipart20160729-106476-l6c1r1-Eagan_firmware_inline.jpg
...except, if I try to do that with the last switch I added, here called Silverdale, WA:
07a5bee69e9342a6b69e7cc18b9d37c9_RackMultipart20160729-106476-1mn11il-Silverdale_firmware_inline.jpg
No difference exists between this and the other two switches. How can I manage the firmware on this switch using Management Center?
9 REPLIES 9
Ronald_Dvorak
Honored Contributor
I fully understand, I've just answered your question ..."What are you seeking?
If that isn't possible because the client doesn't support/allow Java I've no clue where to find the same information in EMC - might be that this is one function that isn't yet implemented in the browser view.
Jesse_Ohlsson
New Contributor II
Ronald, I'm not sure you're understanding me. I simply can't run the java-based legacy applications, inventory manager being one of those. What you've captured there is a screenshot of Inventory Manager. I know this, because I've used NetSight since 2007.
I'm trying to find the equivalent place to do this in Management Center's web GUI.
Ronald_Dvorak
Honored Contributor
I'd check if the devices have the same attributes set.... i.e. green check for firmware download.
5650dc5271604d88a6172ecc8ac31748_RackMultipart20160729-43890-1iaju15-inventory_manager_image_info_inline.png
Jesse_Ohlsson
New Contributor II
Ronald, I can't run the legacy java based applications. What are you seeking?
Ronald_Dvorak
Honored Contributor
Could you please provide a screenshot of the following two windows...
- in Inventory manager select the affected switch - I'd like to see the info in the right "general" tab
- then select the "image information" tab and post that also
