upgrade path for netsight to XMC 8.5.2.6
PRobbins
New Contributor II
need confirmation that i can upgrade netsight 8.0.3.53  to XMC 8.5.2.6 via the following path:   Netsight 8.0.3.53 -> XMC 8.3.11 -> XMC 8.2.5.6
I have seen some Extreme documentation that i need to go to an 8.1 version first then 8.3 then 8.5.2.6. but have seen another where it states you can go from 8.0 to 8.3 then 8.5
can someone confirm the correct upgrade path please
1 ACCEPTED SOLUTION
StephanH
Valued Contributor III
The upgrade path you mentioned is correct. Only the release notes are reliable.
Releasenotes 8.3.3
Extreme Management Center 8.3 supports upgrades from Extreme Management Center version 8.0.x, 8.1.x, or 8.2.x (except version 8.2.2).
Releasenotes 8.5.2
Extreme Management Center 8.5.x supports upgrades from Extreme Management Center version 8.2.x, 8.3.x or 8.4.x. If you are upgrading from version 8.1or earlier of NetSight/ Extreme Management Center, you must perform an intermediate upgrade. For example, if you are upgrading from Extreme Management Center 8.1, you must first upgrade to the latest Extreme Management Center 8.2 or 8.3 release, then to 8.5.x.
Regards Stephan
2 REPLIES 2
PRobbins
New Contributor II
Thanks very much for the confirmation
StephanH
Releasenotes 8.3.3
Releasenotes 8.5.2
Regards Stephan
