‎01-25-2021 01:47 PM
Hello Community,
I have installed version Extreme Management Center 8.5.2.6 and unlocked it with Evaluation License. Now I have the following problem. On the web client the help panel is always displayed. If I deactivate it, it opens again when I select a new menu.
I have two suspicions:
- it is normal with an Evalution License
- it is a bug, I have not found anything
I did not find another option under Administrator.
Thanks for all answers.
Greetings
Solved! Go to Solution.
‎01-25-2021 03:57 PM
As far as I remember it should stop popping up once you add at least one managed device. Till then you can try to drag and drop the separator line max to the right so it doesn’t consume your working area much.
Hope that helps,
Tomasz
‎01-25-2021 04:04 PM
This is the Solution.
Hope that helps,
Tomasz
‎01-25-2021 02:00 PM
did you block cookies ?
