NMS Links
Hi all, NMS does not show links between devices after being configured, after some time the links disappear, any idea of what may be happening? The version of NMS is 8.1.2.59.
I can access the switch via ssh through the Mgmt port. Fine. But what I need to know is how can I access the switch via SSH through any of the front ports, 1 to 48. And is there a way to create different Virtual Routers for each vlan.
Hello, In NetSight Policy Manager, I would like to create a set of rules to permit a traffic based on a source IP + source port AND a destination IP range (e.g. 192.168.1.10:80 → 192.168.2.0/24) I can't find how. I can either permit an IP source + po...
Hello, we have installed a new Extreme Management Center. The old one is about 10 years old and in the past we take a backup. But now we installed a new Management and configure all. But i want to use my Maps from One View, where all all Floor plans...
Hello, team, I have several XMC installations under Windows Server 20xx. Now I have a task to change XMC's IP. If I just change IP of WS's network interface, will XMC consider it as its new interface? Or should I configure something inside XMC inse...
| User | Count |
| 102 | |
| 101 | |
| 42 | |
| 19 | |
| 17 |
