XMC Keeps Running Syslog Receiver Configuration
05-25-2020 09:35 AM
Have enabled syslog receiver on all switches in the network, but I am continually getting the messages below in XMC syslog. I’ve subsequently unregistered syslog and this seems to have stopped?
Do you know if this is normal?
The issue is with a lot a switches in the network generating these logs creates a lot of noise in the syslogs.
The other question is why is it keeping running the command when syslog is already in place?
Currently running XMC version: 8.1.7.27
Many thanks in advance
05/25/2020 04:42:48.55 <Info:AAA.logout> Slot-1: User SA_NetSight logout from ssh (192.168.200.11)
05/25/2020 04:42:47.50 <Info:System.userComment> Slot-1: Enabling syslog
05/25/2020 04:42:47.49 <Info:cli.logRemoteCmd> Slot-1: 192.168.200.11 (ssh) SA_NetSight: create log entry "Enabling syslog"
05/25/2020 04:42:46.50 <Info:System.userComment> Slot-1: Added syslog server for :514
05/25/2020 04:42:46.49 <Info:cli.logRemoteCmd> Slot-1: 192.168.200.11 (ssh) SA_NetSight: create log entry "Added syslog server for :514"
05/25/2020 04:42:45.49 <Info:System.userComment> Slot-1: Starting to add syslog server
05/25/2020 04:42:45.49 <Info:cli.logRemoteCmd> Slot-1: 192.168.200.11 (ssh) SA_NetSight: create log entry "Starting to add syslog server"
05/25/2020 04:42:42.97 <Info:cli.logRemoteCmd> Slot-1: 192.168.200.11 (ssh) SA_NetSight: show config ems
05/25/2020 04:42:41.40 <Info:AAA.LogSsh> Slot-1: Msg from Master : Did password authentication for user SA_NetSight (192.168.200.11)
05/25/2020 04:42:41.39 <Info:AAA.authPass> Slot-1: Login passed for user SA_NetSight through ssh 192.168.200.11)
05/24/2020 16:42:48.58 <Info:AAA.logout> Slot-1: User SA_NetSight logout from ssh (192.168.200.11)
05/24/2020 16:42:47.55 <Info:System.userComment> Slot-1: Enabling syslog
05/24/2020 16:42:47.54 <Info:cli.logRemoteCmd> Slot-1: 192.168.200.11 (ssh) SA_NetSight: create log entry "Enabling syslog"
05/24/2020 16:42:46.55 <Info:System.userComment> Slot-1: Added syslog server for :514
05/24/2020 16:42:46.54 <Info:cli.logRemoteCmd> Slot-1: 192.168.200.11 (ssh) SA_NetSight: create log entry "Added syslog server for :514"
05/24/2020 16:42:45.55 <Info:System.userComment> Slot-1: Starting to add syslog server
05/24/2020 16:42:45.54 <Info:cli.logRemoteCmd> Slot-1: 192.168.200.11 (ssh) SA_NetSight: create log entry "Starting to add syslog server
05-30-2020 07:33 PM
Hello Martin,
Check to see if syslog refresh or auto syslog configuration is enabled:
Thanks
-Ryan
