Radio power being limited on some APs not others
w1f1n00b
Contributor II
Seeing the following warning in buffered log on some APs
Warning - ah_dcd: wifi: wifi1: Power 16 exceeds HW limit(14), forced to 14
Region Code: FCC
Country Code: 840
I’ve checked and have other APs, same model, FW, etc. that are running at powers all the way up to 20. Any ideas why some APs acting differently?
1 ACCEPTED SOLUTION
w1f1n00b
Contributor II
I was able to determine this is only happening on ch36 when radio is set to 40MHz wide.
GTAC closed the case after stating it was FCC regulation, as the regulatory limit reported in CLI is 14. I’ve reached out to my SE to see if he’s able to provide any more detailed info.
6 REPLIES 6
jason_hills
New Contributor III
Hi
Is this a specific model, as the AP150W is limiting its wifi1 intro 8dBm but other APs in same VIQ and radii profile at operating tat the max power in the radio profile.
APs powered by AC power, one is powered by poe+.
I have a posted a question in the community
w1f1n00b
Contributor II
SamPirok
Community Manager
Hi @w1f1n00b, it shouldn’t be regulated differently based on what I’m seeing in the 802.11 a/h/j/n/ac/ax documentation. If you have the time to look in to this, I’d recommend pulling some tech data and opening a case so we can dig in to this with you a bit more.
w1f1n00b
Contributor II
@Sam Pirok , any idea if ch36 is regulated differently than other UNII-1 channels in USA?
