05-10-2021 02:49 PM
Seeing the following warning in buffered log on some APs
Warning - ah_dcd: wifi: wifi1: Power 16 exceeds HW limit(14), forced to 14
Region Code: FCC
Country Code: 840
I’ve checked and have other APs, same model, FW, etc. that are running at powers all the way up to 20. Any ideas why some APs acting differently?
Solved! Go to Solution.
06-08-2021 11:58 AM
I was able to determine this is only happening on ch36 when radio is set to 40MHz wide.
GTAC closed the case after stating it was FCC regulation, as the regulatory limit reported in CLI is 14. I’ve reached out to my SE to see if he’s able to provide any more detailed info.
06-13-2021 09:19 AM
Hi
Is this a specific model, as the AP150W is limiting its wifi1 intro 8dBm but other APs in same VIQ and radii profile at operating tat the max power in the radio profile.
APs powered by AC power, one is powered by poe+.
I have a posted a question in the community
06-08-2021 11:58 AM
05-18-2021 06:27 PM
Hi
05-18-2021 01:03 PM
