Extreme Control TLS Alert
RobertD1
Contributor III
Hello,
Rather than wasting time troubleshooting the below error I wondered if the Extreme Control Engine will reject older encryption protocols such as SSL V3.0?
Old Windows XP with 802.1x PEAP:
Event:
eap_peap: TLS Alert write:fatal:handshake failure eap_peap: Failed in __FUNCTION__ (SSL_read): error:1408A0C1:SSL routines:ssl3_get_client_hello:no shared cipher eap_peap: System call (I/O) error (-1) eap_peap: TLS receive handshake failed during operation
Thanks,
Rob
1 ACCEPTED SOLUTION
Robert_Haynes
Correct. Control will reject any SSLv3 based encipherment. It will also reject a core list of now defunct / legacy ciphers from older clients as listed in GTAC KB @ https://extremeportal.force.com/ExtrArticleDetail?an=000100637.
6 REPLIES 6
Ryan_Yacobucci
Robert_Haynes
Thanks Robert!
Based on your response it does look like the issue is that neither the client or server can agree on a cipher to use after taking a capture of the client hello.
Trace shows client hello...
The enterasys.tomcat.ciphers list:
enterasys.tomcat.ciphers=TLS_RSA_WITH_AES_128_CBC_SHA,TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA,TLS_RSA_WITH_AES_128_CBC_SHA256,TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256,ECDHE-ECDSA-AES256-GCM-SHA384,ECDHE-RSA-AES256-GCM-SHA384,ECDHE-ECDSA-AES128-GCM-SHA256,ECDHE-RSA-AES128-GCM-SHA256,ECDHE-ECDSA-AES256-SHA384,ECDHE-RSA-AES256-SHA384,ECDHE-ECDSA-AES128-SHA256,ECDHE-RSA-AES128-SHA256
Thank you for the trace. The client cipher list presented is wholly deprecated at this point, a collection of RC4 (cryptographically weak), CBC (Beast/Poodle Attacks) and defunct EXPORT ciphers. OpenSSL long ago deprecated these ciphers which our Control appliance uses.
