‎02-23-2024 03:51 AM
We've purchased an Extreme Networks 5420F-24P switch and are trying to connect to the interface via putty or MobaXterm with the configuration indicated in the Guide:
Baud rate: 9600
Data Bits: 8
Stop bit: 1
Parity: none
Flow control: none
But it dont work.
Can anyone help us?
Sincerely.
Solved! Go to Solution.
‎02-23-2024 05:34 AM
Carsten is correct, the speed for these universal switches is 115200.
‎02-23-2024 08:18 AM
Are you able to connect the management port to your network and get a link?
Bill
