BD 8810 does not recognize Extreme XFP
HarrySo
New Contributor III
Hi Experts!
We have two BD8810 with 10G8Xc modules installed. Now we have the Problem, that some of the inserted XFPs are not recognized. They are marked as !Unknown.
This happens with FW 15.7, 15.6.2.12, 15.5.4.2.
Has anyone seen this on Extreme devices?
10 REPLIES 10
OscarK
I think you might be looking at an XFP with a problem. The optic-info looks good but if you get error messages like that there are problems reading information from that XFP. It looks like these are from 2007, maybe the Unknown reporting XFP's are broken ?
HarrySo
New Contributor III
I've found now in the log the following Output:
Slot-1: aspendiags: Unable to open XFP-EEPROM device for port 6, rv -1
HarrySo
New Contributor III
Hi, yes i'm sure. Here the Output: Ports 1:6-8
Port 6
XFP Vendor: Opnext Inc.
XFP Part Number: TRF2000EN-LF171
XFP Serial Number: 0724A-80111
XFP Revision: 04
Date Code: 070615
Transceiver Type: XFP
Connector: LC
10GE Compliance: 10GBASE-SR/SW
XFP Supported: yes
XFP Display String: 10GBase-SR
XFP CMU Lock: 1
XFP CDR Lock: 1
XFP PowerDown: 0
XFP Signal Present: 1
XFP Mod NR: 0
XFP Tx Disable: 0
XFP Int: 0
XFP Mod Sel: 0
XFP Phy Mux Sel: 0
XFP Phy Mode: 0
XFP Phy Clock Mode: 1
XFP Phy LASI: 0
XFP Phy LOS: 1
Port 7
XFP Serial Number: 0724A-80258
XFP Revision: 04
Date Code: 070615
Connector: LC
XFP Supported: yes
XFP CMU Lock: 1
XFP CDR Lock: 1
XFP PowerDown: 0
XFP Mod NR: 0
XFP Tx Disable: 0
XFP Int: 1
XFP Mod Sel: 0
XFP Phy Mux Sel: 0
XFP Phy Mode: 0
XFP Phy LASI: 0
XFP Phy LOS: 1
Port 8
XFP Serial Number: 0733A-80088
XFP Revision: 04
Date Code: 070815
Connector: LC
XFP Supported: yes
XFP CMU Lock: 1
XFP CDR Lock: 1
XFP PowerDown: 0
XFP Mod NR: 0
XFP Tx Disable: 0
XFP Int: 1
XFP Mod Sel: 0
XFP Phy Mux Sel: 0
XFP Phy Mode: 0
XFP Phy LASI: 0
XFP Phy LOS: 1
OscarK
okay, !UNKN is indeed different from that solution I gave you. Are you sure these are extreme networks XFP's ?
What is the output of debug hal show optic-info ?
HarrySo
New Contributor III
Hi Oscar!
Thank you for your answer. I've tried now three different Firmware Releases, but the !Unknown Status is always here. So, after a reboot, it's not gone 😉
1:1 VR-Default E A OFF 10000 10000 FULL FULL NONE 1:1 XFP_SR
1:2 VR-Default E A OFF 10000 10000 FULL FULL NONE 1:2 XFP_SR
1:3 VR-Default E R OFF 10000 FULL 1:3 NONE
1:4 VR-Default E R OFF 10000 FULL 1:4 NONE
1:5 VR-Default E R OFF 10000 FULL NONE
1:6 VR-Default E A OFF 10000 10000 FULL FULL NONE !UNKN
1:7 VR-Default E A OFF 10000 10000 FULL FULL NONE 1:7 XFP_SR
1:8 VR-Default E A OFF 10000 10000 FULL FULL NONE 1:8 XFP_SR
2:1 VR-Default E A OFF 10000 10000 FULL FULL NONE 1:1 XFP_SR
2:2 VR-Default E A OFF 10000 10000 FULL FULL NONE 1:2 XFP_SR
2:3 VR-Default E R OFF 10000 FULL 1:3 NONE
2:4 VR-Default E R OFF 10000 FULL 1:4 NONE
2:5 VR-Default E R OFF 10000 FULL NONE
2:6 VR-Default E R OFF 10000 FULL !UNKN
2:7 VR-Default E A OFF 10000 10000 FULL FULL NONE 1:7 XFP_SR
2:8 VR-Default E A OFF 10000 10000 FULL FULL NONE 1:8 XFP_SR
