debug autonegotiation problem
M_Nees
Contributor III
We have some clients with gigabit TP NIC on a X450-G2 (EXOS V16.1.3.6 patch1-4) - but they only connect with 100MB full duplex. (i investigate the problem via trial and error)
My concern is now - how can i troubleshoot this from switch CLI?
1) How can i see more what happenend regarding autoneg on that specific port - how can i increase log level to debug this ?
Which log modul have to be modified ?
2) On enterasys Switches (EOS) i could determine via "set port advertise" which speed or duplex modes are advertised to the partner AND which speed / duplex the partner offers.
System(rw)->show port advertise ge.4.36
ge.4.36 capability advertised remote
----------------------------------------------10BASE-T yes yes no
10BASE-TFD yes yes no
100BASE-TX yes yes no
100BASE-TXFD yes yes no
1000BASE-X no no no
1000BASE-XFD no no no
1000BASE-T no no no
1000BASE-TFD yes yes no
other no no yes
pause yes no no
Apause yes no no
Spause yes no no
Bpause yes yes noHow can i achieve this with EXOS ?
Regards
12 REPLIES 12
BradP
Hi Matthias,
I'll open a case on your behalf and then email you. Stay tuned.
M_Nees
Contributor III
Hi Brad,
open a GTAC is currently cumbersome.
Can you please tell me how can i increase the log level for autonegotiation on a TP port.
Securestack can check the cable through a cable-test / cable-check command - are there any change to have that on EXOS ?
Regards,
Matthias
BradP
Hi Matthias,
I know there is a way through the EXOS shell/debug mode in order to see what speeds are being advertised on our port as well as which speeds are being advertised on the wire. Please open up a GTAC case and we can get it sorted out.
Thanks
Brad
