Downgrade Firmware Version XOS over switch x440
‎04-19-2016 05:36 PM
I need to make a greater Downgrade to a smaller version on a switch extreme x440 , what is the procedure?
Keep in mind that the version I want to get the just installed because of an error and should give isntalarla because I have not even restarting the switch and these teams are in production.
15 REPLIES 15
‎04-19-2016 05:59 PM
Hello Jairo,
It looks like it installed just fine.If you are trying to install a different image then you just need to go through the same process you went through to get 16.1.3.6 on the switch.
‎04-19-2016 05:57 PM
* X440-24p.3 # sh version images
Card Partition Installation Date Version Name Branch
Switch primary Fri Nov 7 18:35:13 UTC 2014 15.5.3.4 summitX450-15.5.3.4.xos v1553b4
Switch secondary Tue Apr 19 16:38:34 UTC 2016 16.1.3.6 summitX-16.1.3.6-patch1-2.xos 16.1.3.6-patch1-2
Switch secondary Tue Apr 19 16:39:44 UTC 2016 16.1.3.6 summitX-16.1.3.6-patch1-2-ssh.xmod 16.1.3.6-patch1-2
‎04-19-2016 05:54 PM
Can you give us the "show version images" and "show switch" output?
‎04-19-2016 05:50 PM
I want to move from version summitX-16.1.3.6-patch1-2.xos to version summitX-15.6.4.2-patch 1-3
