Extreme CPU usage of HAL process : Upgrading the bootROM on Summit x440G2 ?
03-02-2020 07:29 AM
Some of our X440G2 switches show high temperatures (around 90°C)
Fans seem to work. So when looking at CPU usage, I’ve noticed the HAL process has a max usage of 99,9% and a constant 20%.
After reading this article I was wondering if the bootROM on the device should get an upgrade.
Currently, IMG version is 22.7.1-2, bootROM is 1.0.1.8
Is it good practice to do the upgrade? Where can I obtain the file?
Maybe there are other ways I should try prior to upgrading?
Thanks!
Daniël
03-02-2020 10:16 AM
Hi Nikolay,
Thanks for the reply.
I’ve seen the article you mentioned. It’s because of this advice to “only upgrade BootROM when instructed by GTAC” that I started the topic here. If 1.0.1.8 is already the latest I have my answer, thx 🙂
If you have any suggestions regarding the problem with HAL process..?
Kind regards,
Daniël
03-02-2020 08:44 AM
Hello Dani_tH,
Bootrom 1.0.1.8 is the latest version for X440G2.
Also please check - https://gtacknowledge.extremenetworks.com/articles/Q_A/Do-I-need-to-upgrade-bootrom-on-my-Summit-swi...
Best Regards,
Nikolay
