Facing issue to in BD 8810 switch Backup issue.Please help
‎05-11-2015 08:35 AM
Hi Friends,
I am facing issue with BD 8810 switch .whenever trying to take backup its showing error.
Used commands :-TFTP PUT -V VR-Default Primary.cfg
13 REPLIES 13
‎05-12-2015 08:36 AM
https://community.extremenetworks.com/extreme/topics/restore_from_backup-10oqux
Refer above blog. It may clear your all doubt regarding configuration backup.
‎05-12-2015 05:14 AM
Hi, Sumit!
1. Difference between Upload and tftp put commands in file format in uploaded file.
Upload - .xsf file
tftp put - .cfg file
2. Have you trying put file to another PC? It's can be trouble with firewall in your PC/lap-top.
Thank you!
Upload - .xsf file
Thank you!
If you use vr-Default main ports - then "tftp put vr vr-Default primary.cfg"
If you use MGMT port of MSM module - then "tftp put vr vr-Mgmt primary.cfg" or do not specify VR.
Also you have to look that you home folder in TFTP server is configured right.
Also you have to look with "ls" command that primary.cfg is present in switch
Dear Alexandrp,
Thanks for your valuable support .
now i am able to take backup .
Regards
Sumit
Regards
Sumit
