Facing issue to in BD 8810 switch Backup issue.Please help
Sumit_Johari
New Contributor II
Hi Friends,
I am facing issue with BD 8810 switch .whenever trying to take backup its showing error.
Used commands :-TFTP PUT -V VR-Default Primary.cfg
13 REPLIES 13
Sumit_Tokle
Contributor
https://community.extremenetworks.com/extreme/topics/restore_from_backup-10oqux
Refer above blog. It may clear your all doubt regarding configuration backup.
Alexandr_P
Valued Contributor
Hi, Sumit!
1. Difference between Upload and tftp put commands in file format in uploaded file.
Upload - .xsf file
tftp put - .cfg file
2. Have you trying put file to another PC? It's can be trouble with firewall in your PC/lap-top.
Thank you!
If you use vr-Default main ports - then "tftp put vr vr-Default primary.cfg"
If you use MGMT port of MSM module - then "tftp put vr vr-Mgmt primary.cfg" or do not specify VR.
Also you have to look that you home folder in TFTP server is configured right.
Also you have to look with "ls" command that primary.cfg is present in switch
Dear Alexandrp,
Thanks for your valuable support .
now i am able to take backup .
Regards
Sumit
