No mac address showing for enabled and active port
Miba89
New Contributor II
Dear Extreme,
One of the ports on our X450G2 stack is showing up as enabled and active. However when we want to see the mac address of this port, nothing is being listed?
How is this possible? How can we figure out the mac address of this port?
Slot-1 LANSTACK.45 # show port 2:13 no
Port Summary
Port Display VLAN Name Port Link Speed Duplex
# String (or # VLANs) State State Actual Actual
2:13 PCs PCs E A 10 FULL
Slot-1 DCK-LANSTACK.47 # show fdb port 2:13
MAC VLAN Name( Tag) Age Flags Port / Virtual Port List
These are the details of our stack:
SysName: LANSTACK
System Type: X450G2-48p-10G4 (Stack)
SysHealth check: Enabled (Normal)
Recovery Mode: All
System Watchdog: Enabled
Slot: Slot-1 * Slot-2
Current State: MASTER BACKUP (In Sync)
Image Selected: primary primary
Image Booted: primary primary
Primary ver: 30.7.1.1 30.7.1.1
patch1-103 patch1-103
Secondary ver: 30.7.1.1 30.7.1.1
Config Selected: primary.cfg
Config Booted: primary.cfg
7 REPLIES 7
Thanks for the hint, Brian. I wasn't able to check physically yet, since other work came in between. But i'll keep that in mind.
CThompsonEXOS
"show ports 2:13 utilization" will show if that device is sending traffic.  If it is not, then the switch will not learn a fdb.  EXOS learns on the source mac:
ExtremeXOSĀ® User Guide (extremenetworks.com)
Based on the auto negotiation being at "10", is it possible that device is asleep/dormant?
Thanks,
Chris Thompson
Basd
Dear Christopher,
Thank you very much for the reply.
Using the "utilization" command shows me 0 packets received or 0 packets send. Which means the device is indeed either in sleep mode or dormant.
I'll ask someone to check physically.
Kind regards,
Michiel
