Sammit x670 problem with indicate of alarm for fans in slot 1 - but works propely
‎07-29-2016 07:02 AM
sammit x670-48V
On the front pannel I can see the allarm for fans 1-3
07/29/2016 08:36:14.83 Switch, Code 5: Air flow mismatch detected in slot 1. Ensure all fantray and psu models are of similar air flow. (X670-48x, P/N: 800400-00-11, S/N: 1341N-40420, Rev: 11.0)07/29/2016 08:36:09.81 Switch, Code 5: Air flow mismatch detected in slot 1. Ensure all fantray and psu models are of similar air flow. (X670-48x, P/N: 800400-00-11, S/N: 1341N-40420, Rev: 11.0)
07/29/2016 08:36:05.96 User admin logout from telnet (192.168.0.2)
07/29/2016 08:36:04.93 Switch, Code 5: Air flow mismatch detected in slot 1. Ensure all fantray and psu models are of similar air flow. (X670-48x, P/N: 800400-00-11, S/N: 1341N-40420, Rev: 11.0)
07/29/2016 08:36:02.50 Login passed for user admin through telnet (192.168.0.2)
07/29/2016 08:35:59.81 Switch, Code 5: Air flow mismatch detected in slot 1. Ensure all fantray and psu models are of similar air flow. (X670-48x, P/N: 800400-00-11, S/N: 1341N-40420, Rev: 11.0)
I can see that all fans are works propely
X670-48x.7 # show fans
Slot-1 FanTray-1 information:
State: Operational
NumFan: 2
PartInfo: 1341N-41182 450300-00-03
Revision: 3.0
Fan-1: Operational at 3255 RPM
Fan-2: Operational at 6301 RPM
Slot-1 FanTray-2 information:
State: Operational
NumFan: 2
PartInfo: 1341N-41183 450300-00-03
Revision: 3.0
Fan-1: Operational at 3091 RPM
Fan-2: Operational at 6553 RPM
Slot-1 FanTray-3 information:
State: Operational
NumFan: 2
PartInfo: 1341N-41184 450300-00-03
Revision: 3.0
Fan-1: Operational at 3212 RPM
Fan-2: Operational at 6826 RPM
X670-48x.9 # show version Switch : 800400-00-11 1341N-40420 Rev 11.0 BootROM: 2.0.1.7 IMG: 16.1.3.6
PSU-1 : Internal PSU-1 800460-00-04 1341W-82003
PSU-2 : Internal PSU-2 800460-00-04 1341W-81886
Image : ExtremeXOS version 16.1.3.6 16.1.3.6-patch1-2 by release-manager
on Mon Apr 4 14:53:20 EDT 2016
BootROM : 2.0.1.7
Diagnostics : 6.3
Why it alarms?
State: Operational
NumFan: 2
Revision: 3.0
State: Operational
NumFan: 2
Revision: 3.0
State: Operational
NumFan: 2
Revision: 3.0
BootROM : 2.0.1.7
Diagnostics : 6.3
Why it alarms?
4 REPLIES 4
‎07-29-2016 10:45 AM
Thanks a lot, problem is solved
‎07-29-2016 09:23 AM
"All installed fan modules must blow air in the same direction and must match the airflow direction of the installed power supplies."
from.....
http://documentation.extremenetworks.com/summit/summit_family_hw_install/replace_fan/c_airflow-direc...
So you'd need to replace the
10927 - 550W AC Power Supply module for Summit switches, Back-to-Front airflow
with
10925 - 550W AC Power Supply module for Summit switches, Front-to-Back airflow
from.....
with
‎07-29-2016 09:12 AM
Thanks for quick answer!
Yes slot 1-3 is 17111
and PSU both are 10927
summit 17103
Directions must be equal?
summit 17103
‎07-29-2016 07:19 AM
link to datasheet...
http://learn.extremenetworks.com/rs/extreme/images/Summit-X670V-48t-DS.pdf
I'm not an expert but as the alarm show "Air flow mismatch" could it be that the chassis that was ordered isn't populated with the correct PSUs.
I.e. if you go to page 8 the chassis for order number 17201 is for airflow "front to back" so you must make sure that you also order "front to back" PSUs.
Could you confirm that you've the correct ones installed.
