‎12-28-2020 07:16 PM
Hello gentlemen,
I need help from the most experienced.
I have the following vlans configured on my core switch:
1 - Default - 192.168.1.2/24
2 - IT - 172.17.41.1/24
3 - Fin - 172.17.36.1/24
4 - My Default gateway is 192.168.1.1 (My Firewall).
I don't want communication between vlans, but I need them to be able to go out to the internet, going through the firewall.
I have tried to configure static route, enable ipforwarding, ACL denying traffic between vlans when ipforwarding is enabled, but still without success.
Can someone please help me?
Sorry for the mistakes I use google translate.
Solved! Go to Solution.
‎12-28-2020 07:18 PM
Jackson,
First shot is to remove the ipaddress from the vlans and put them on the vlan interface of the firewall.
If you want more specific answers you’ll have to share a topology design.
Mig
‎12-28-2020 07:17 PM
XCM8810.1 # sh config "vlan"
# Module vlan configuration.
configure vlan default delete ports all
configure vr VR-Default delete ports 1:1-48
configure vr VR-Default add ports 1:1-48
configure vlan default delete ports 1:1, 1:36, 1:41
create vlan "Fin"
configure vlan Fin tag 36
configure vlan Fin protocol IP
create vlan "TI"
configure vlan TI tag 41
configure vlan Default add ports 1:1 tagged
configure vlan Default add ports 1:2-35, 1:37-40, 1:42-48 untagged
configure vlan Fin add ports 1:36 untagged
configure vlan TI add ports 1:41 untagged
configure vlan Default ipaddress 192.168.1.2 255.255.255.0
configure vlan TI ipaddress 172.17.41.2 255.255.255.0
configure vlan Fin ipaddress 172.17.36.2 255.255.255.0
XCM8810.2 # sh iproute
Ori Destination Gateway Mtr Flags VLAN Duration
#s Default Route 192.168.1.1 1 UG---S-um--f Default 0d:0h:8m:37s
d 172.17.36.0/24 172.17.36.2 1 -------um--- Fin 0d:0h:8m:37s
#d 172.17.41.0/24 172.17.41.2 1 U------um--f TI 0d:0h:8m:37s
#d 192.168.1.0/24 192.168.1.2 1 U------um--f Default 0d:0h:8m:37s
