X460-G2 connecting 10 meter DAC Cable possible ?
‎08-27-2016 08:20 AM
we want to uplink several X460-G2 switches via 10 meter Copper DAC Cable to a S4.
But it seems not working. Does anybody know if the X460-G2 10Gb optic ports have the needed PHY unit to get 10m Cables runnig ??
Behaviour:
S4 port Link is Up / X460-G2 port stay down - but DAC cable will be recognize correctly.
Switch-1.8 # sh port 52 configuration no-refresh
Port Configuration
Port Virtual Port Link Auto Speed Duplex Flow Load Media
router State State Neg Cfg Actual Cfg Actual Cntrl Master Pri Red
UPL-Core VR-Default E R OFF 10000 FULL 52 SF+_CX10
> indicates Port Display Name truncated past 8 characters
X460G2-48p-10G4 / EXOS 16.1.3.6-patch1-9
Behaviour:
Port Configuration
3 REPLIES 3
‎10-13-2016 12:13 PM
Adding the GTAC article link:
https://gtacknowledge.extremenetworks.com/articles/Q_A/Is-it-possible-to-connect-a-5-or-10-meter-Coo...
‎08-27-2016 08:47 AM
i found an answer in the X460-G2 Datasheet - it is not possibel!
Section: Transceiver Support Matrix
It will only work within a the optional VIM Module!
Yes. Use either max 3m DAC for PHYLESS or go FO SFP+ SR modules.
VIM-2x will definitely support 5m and 10m DAC cable.
