How to enable STP in Extreme Switches?
Thavamani_Shanm
New Contributor III
is it possible configure STP for selected Ports alone? If possible please share the stps...
4 REPLIES 4
Thiago_da_Silva
You can use the commands to see the stpd working.
show stpd
or
show stpd < name stpd >
Thiago_da_Silva
Hello Thavanami, I have the script of the configuration of the STPD. Do you question is about spanning-tree or STP ( Software of the inline-power - POE )?
Send my script of spanning-three.
create stpd EX: VLan: 2000 --> STPD_2000config stpd add vlan ports emistp
config stpd add vlan ports dot1d
or
config stpd ports link-type edge edge-safeguard enable bpdu-restrict
config stpd tag
config stpd mode dot1w
enable stpd
enable stpd
Kawawa
Hi Thavamani, By default, the Default VLAN is already a member of STP Domain s0. If you created any additional VLANs, you could add those ports to the STP s0 domain using the following command:
configure stpd add vlan ports The above command allows you to be specific about the ports you want to add. If you do however wish to add all the ports, the auto-bind feature outlined in the article Dorian provided can be very handy.
Dorian_Perry
Hi Thavamani,
Take a look the GTAC Knowledge article How to configure RSTP in EXOS
