‎12-09-2021 11:52 AM
Hi all
I am building a VOSS lab in GNS3 and have the following simple topology
There is 1 VLAN configured (VLAN 10) which should be trunked between both VSPs and then accessible from the router on Gi1/3 on VSP1
The Cisco router has a single interface with an IP 10.10.0.100
DC1-VSP1 config:
DC2-VSP2 config
I can ping from the cisco router (10.10.0.100) to DC1-VSP1 VLAN 10 IP address (10.10.0.1) but not DC2-VSP1 (10.10.0.2)
DC1-VSP1 VLAN 10 IP address (10.10.0.1) can ping DC2-VSP1 (10.10.0.2), and vice-versa.
DC1-VSP1:1#ping 10.10.0.2
10.10.0.2 is alive
DC2-VSP1:1#ping 10.10.0.1
10.10.0.1 is alive
I am sure I have missed something obvious but I don't see it, can anyone help?
Thanks in advance
DC1-VSP1 config:
# CLI CONFIGURATION
prompt "DC1-VSP1"
password password-history 3
# VLAN CONFIGURATION
vlan members remove 1 1/1,1/3
vlan create 10 name "VLAN10" type port-mstprstp 1
vlan members 10 1/1,1/3 portmember
interface Vlan 10
ip address 10.10.0.1 255.255.255.0 0
exit
# PORT CONFIGURATION - PHASE I
interface GigabitEthernet 1/1
encapsulation dot1q
exit
# PORT CONFIGURATION - PHASE II
interface mgmtEthernet mgmt
auto-negotiate
exit
default-vlan-id 0
no shutdown
exit
interface GigabitEthernet 1/3
no shutdown
exit
DC2-VSP2 config
# CLI CONFIGURATION
prompt "DC2-VSP1"
vlan members 10 1/1 portmember
interface Vlan 10
ip address 10.10.0.2 255.255.255.0 0
exit
encapsulation dot1q
exit
auto-negotiate
exit
default-vlan-id 0
no shutdown
exit
10.10.0.2 is alive
10.10.0.1 is alive
Thanks in advance
Solved! Go to Solution.
1 ACCEPTED SOLUTION
‎07-26-2023 06:09 AM
It's out now.
Starting with the 8.10.1.0 version, the hardware is based on based on 5520-24T Universal Switch. Also, in addition to control plane features, there will be limited data plane capabilities, equivalent to what is supported on ExtremeAccess Platform 1400 (XA1400).
10 REPLIES 10
‎12-10-2021 02:23 AM
Hi Ben,
the VOSS GNS3 images don't have a ForwardingPlane, and without that you can not ping through the a VOSS GNS3 device.
regards
Marlon
regards
Marlon
