debug netlogin XOS
debug netlogin XOS
M_Nees
Contributor III
Hi Folks,
how can i debug the following error message regarding mac authentiication on recent XOS 15.5.4.2 (BD8810) and solving the problem?
Reboot of the end-system does not help. Shutting down netlogin - end-system running at once over the manually configured vlan.
MSM-A: Authentication failed for Network Login MAC user 18A905BB9E50 Mac 18:A9:05:BB:9E:50 port 7:39
Here the show netlogin for this port:
show netlogin port 7:39
Port : 7:39
Port Restart : Disabled
Allow Egress : None
Vlan : Default
Authentication : mac-based
Port State : Enabled
Guest Vlan : Disabled
Auth Failure Vlan : Disabled
Auth Service-Unavailable Vlan : Disabled
MAC IP address Authenticated Type ReAuth-Timer User
18:a9:05??9e:50 0.0.0.0 No MAC 0
(B) - Client entry Blackholed in FDB
Port : 7:39
Allow Egress : None
Vlan : VTelefon
Number of Clients Authenticated : 2
The is a very simple MAC Auth so i cannot understand why the netlogin should failed !
As a background information i run an update from XOS 12.6.2.10 to 15.5.4.2 yesterday evening.
7 REPLIES 7
OscarK
you can debug everything on EXOS by adding events to the log filter with a lower severity, even severity debug-data/verbode/summary.For the debug severity you need to enable log debug-mode.
M_Nees
Contributor III
Hi OscarK,
this does not help because we use MAC auth with RADIUS.
Do you (or anybody else) know how i can debug this MAC Authentication process ?
Regards
