Enterasys survey AP power config
Víctor_Yoli
Hello all,
I'm doing a wireless survey with an Enterasys 3715e for the first time. The AP was configured by someone else to run without a controller. It broadcasts a custom SSID that he set up. I can read it just fine. My issue is that I'm unsure how to find out the current power setting. I know that I can "cset power 0" to change it but I started surveying with whatever power setting is was set to. I've looked through the "cget config" and can't decipher what the power setting is. Any advice helps.
Thanks
6 REPLIES 6
marconet_22
Contributor
Hi
Where i can find cli commands about extreme enterasys?
Ronald_Dvorak
Honored Contributor
As you use the model with the ext. antenna please keep in mind to configure the correct one.
Otherwise you could end up exceeding the max allowed EIRP in your region.
In that case your site survey wouldn't be valid.
i.e. the 3dBi omni would look like that on the CLI ...
# cget config | grep antenna
radio 0 antennaType left 0xf00f middle 0xf00f right 0xf00f
radio 1 antennaType left 0xf00e middle 0xf00e right 0xf00e
radio 2 antennaType left 0x0 middle 0x0 right 0x0
antennaPortAtt 0 -1[dB]
antennaPortAtt 1 -1[dB]
hsachse
New Contributor III
Cool, did'nt know that the CLI included some unix shell commands.
Tony1
New Contributor III
You can add a grep to the "cget config"
For example:
# cget conf | grep Power
minPower 0 4
maxPower 0 15
atpcAdjPower 0 0
minPower 1 4
maxPower 1 15
atpcAdjPower 1 0
