ā04-09-2024 08:48 AM
We currently have some 410C access points and AP4000s managed in XIQ. When doing a wireless survey using Ekahau the AP names show up as 'Measured AP-XX:XX' is there a way to broadcast the name of the AP for the survey?
ā04-10-2024 10:34 AM
Hello Anthony,
About the Hostname In beacon setting:
Activate iBeacon for or APs that have internal iBeacon transmitters and that belong to a network policy. Slide the toggle to ON.
To use this setting, you must first define the iBeacon service in the associated network policy and then turn it on via the Device Management page.
Before you begin, configure a network policy.
Consider the following:
You can configure the embedded iBeacon transmitter in APs. As transmitters, these beacons broadcast numerical advertisements that trigger an action on Bluetooth-enabled devices that come within range. For example, an app running on a mobile device might react to an iBeacon signal by displaying welcome messages, sale announcements, or coupons.
You can also automatically create a UUID with an online UUID generator, such as the one at https://www.uuidgenerator.net/.
BR,
ā04-10-2024 07:09 AM
Hi
For XIQ follow this guide: https://extreme-networks.my.site.com/ExtrArticleDetail?an=000080401
-Gareth
ā04-10-2024 08:09 AM
Thank you Gareth! I created a new management option with 'Hostname in beacon' enabled and applied to my test network policy/test AP but I'm still unable to see the name of the AP in a survey.
ā04-10-2024 05:28 AM
we turned this on in the wlan configuration
