Pascal,
Based on my lab, it is working fine with 3935i as below information.
I will ask the article creator to change details.
And please notice that I used fallback feature of LACP to ensure connection when AP is not set to use LACP so that you can change setting of the AP after all.
AP info
![877cc6064444450f84207e96d4c44015_RackMultipart20161220-58445-ohuk7-3935i_LACP_inline.png 877cc6064444450f84207e96d4c44015_RackMultipart20161220-58445-ohuk7-3935i_LACP_inline.png](/t5/image/serverpage/image-id/3916iFB77BA7C9370E9FA/image-size/large?v=v2&px=999)
Switch info
* X440G2-12p-10G4.7 # show sharing
Load Sharing Monitor
Config Current Agg Min Ld Share Dist Ld Share Agg Link Link Up
Master Master Control Active Algorithm Flags Group Mbr State Transitions
1 1 LACP 1 L2 A 1 Y A 13
L2 2 Y A 10
Link State: A-Active, D-Disabled, R-Ready, NP-Port not present, L-Loopback
Minimum Active: (<) Group is down. # active links less than configured minimum
Load Sharing Algorithm: (L2) Layer 2 address based, (L3) Layer 3 address based
(L3_L4) Layer 3 address and Layer 4 port based
Distribution Flags:
A - All: Distribute to all members,
L - Local Slot: Distribute to members local to ingress slot,
P - Port Lists: Distribute to per-slot configurable subset of members,
R - Resilient Hashing enabled.
Number of load sharing trunks: 1
* X440G2-12p-10G4.8 # show lacp lag 1
Lag Actor Actor Partner Partner Partner Agg Actor
Sys-Pri Key MAC Sys-Pri Key Count MAC
1 0 0x03e9 d8:84:66:57:cf:3b 65535 0x0011 2 00:04:96:9b:54:26
Port list:
Member Port Rx Sel Mux Actor Partner
Port Priority State Logic State Flags Port
1 0 Current Selected Collect-Dist A-GSCD-- 1
2 0 Current Selected Collect-Dist A-GSCD-- 2
Actor Flags: A-Activity, T-Timeout, G-Aggregation, S-Synchronization
C-Collecting, D-Distributing, F-Defaulted, E-Expired
* X440G2-12p-10G4.9 # show inline-power info ports 1,2
Port State Class Volts Curr Power Fault
(mA) (Watts)
1 delivering class4 54.0 15 0.800 None
2 delivering class4 54.2 145 7.800 None
* X440G2-12p-10G4.10 #
Thank you.
