AP 3805 yellow LED power
Alexandr_P
Valued Contributor
Hello, all!
Have an AP3805i.
Install guide say that power LED can be red or green
But in my AP3805i only power LED is yellow and steady
790e816ca1684f82991fa13779e616d0_RackMultipart20161220-36055-1jvw1dz-IMG_20161220_094249_inline.jpg
Any ideas?
Thank you!
9 REPLIES 9
Alexandr_P
Valued Contributor
Thank you, Ron!
I'll open case.
Alexandr_P
Valued Contributor
Hi, Nathiya!
AP was working before, but at one time suddenly stuck with yellow power LED.
Switch with connected AP even can't see MAC address of this AP, so I understand that problem with booting.
But why LED is yellow?
Thank you!
Hello, Bin!
1. From your link:
LED 1 Only
Solid Amber - Discovery finished via WDS, but not in progress.
(in one port of switch is EWC in other port is AP, they in one VLAN)
2. I can't see MAC address of this AP on switch port.
Thank you!
Bin
Hello Alexandr,
The color looks like Amber.
It looks the AP initial and discovery in progress via WDS.
Here is the reference, Although the AP mode is difference, I believe that it will be the same
https://gtacknowledge.extremenetworks.com/articles/Q_A/What-do-the-AP3610-LED-colors-represent
Best regards,
Nathiya_Munuswa
Hi Alexandr,
Is it a brand new AP or was it working before?
Regards,
Nathiya M
