I have been in this same boat! I see that this was reported a month ago, but Matthew was also having issues. I would suggest opening a GTAC case if you haven't yet done that. There are some superstars on the support team that will pick up on things in your config that you may not have thought about.
Also, if you have never "tuned" your AP settings out of the box, you should know that a lot of the time the default settings are not the suggested settings.
See this article:
https://gtacknowledge.extremenetworks.com/articles/Q_A/What-are-the-best-radio-settings-for-my-envir...
There is a link in that article to an attached file ("Answer: Click to view file") which is VERY helpful in resolving weird roaming issues. I am refraining from linking the file directly, because it's often updated/repliaced and re-linked from the above KB article.
