AP510e with Mesh connex in radio 2 with physical radio ports 5 and 6 ?
Valter_Veiga
New Contributor III
Hi everybody,
Has anyone tried to use the physical radio ports 5 and 6 ?
https://extremeportal.force.com/ExtrArticleDetail?an=000078786
4 REPLIES 4
Valter_Veiga
New Contributor III
Hi Christoph,
I Have tried to change to Mode 2, Radio 1 - 2.4/5 GHz Sensor, Radio 2 - 5 GHz WLAN
antenna-id external group-1 ml-2452-pna7-01r
antenna-id external group-2 ml-2452-apa2-01
I have tried several antenas, But ..... it doesn't work.
I need a Mesh Connex using the Radio 2  5Ghz and physical radio ports 5 and 6 .
sh wireless meshpoint statistics
         MESHPOINT         TX        RX       TX      RX      TX        RX
                         bytes     bytes     pkts    pkts    kbps      kbps
        MZ_NAVE1_MESH         0         0       0       0     0 k     0 k
Total number of meshpoint displayed: 1
Hello Valter,
This issue may lie elsewhere, we'll need visibility into your config.
If testing in your lab please make sure that the APs are at least a few feet apart and that the radio power is turned all the way down to 1db.
BR
Christoph S.
Hi Christoph,
The antenas are apart a 15 metters in a remote LAB.
If I disconnect the Antenas 1 and 2 the MESH it doesn't see the neighors.
The system:\dataplane\wireless\radio\radio2-proximity  is clean (after reboot).
Case Number: 02652690
Christoph_S
Hello Valter,
What would you like to know about 2 antenna connectors?
I've updated the above article and included the AP schematic: https://extremeportal.force.com/ExtrArticleDetail?an=000078786
If using only 2 antennas on the 5GHz radio you'll need to configure radio 2 antenna-mode to match.
To know which connectors to use please run the following CLI commands when in radio 2 configs:
#antenna-mode ?
This will tell you what mode to use and which connectors to use.
Best regards,
Christoph S.
