ap6521 add 5ghz
ap6521 add 5ghz
Demm21
Hello.
I try to add 5ghz on ap6521
And I can't create second interface in radios for 5ghz in ap profile. error "interface name is not supported"
is it hardware limitation?
1 ACCEPTED SOLUTION
Christoph_S
The AP6521 APs can only have one radio on at a time. From GUI you can clearly see under Wireless that only one radio can be selected at a time. The 1 in AP6521 refers to single radio.
There is no Interface radio 2 on this unit, you can either set interface radio 1 to 2.4GHz or 5GHz, but not both.
Thank you,
Chris
Christoph S.
5 REPLIES 5
RobertZ
if the hardware you have has one radio than maybe but you would get different error not ' interface name is not supported'.
Can you provide us with the name you are trying to use that is causing you that error? Also please provide the output of CLI command ' show wireless radio'
