‎05-02-2019 03:54 AM
Hi everyone
Function auto shutdown how does it work? I disconnect the network but the SSID was not turned off.
Solved! Go to Solution.
1 ACCEPTED SOLUTION
‎05-02-2019 12:43 PM
The Auto Shutdown feature causes the WLAN to shut down when certain criteria are met. It also allows administrators to set the operating days and hours of certain WLANs for security or bandwidth purposes.
18 REPLIES 18
‎05-07-2019 12:58 AM
Hello @Robert Zarzycki , Can you help me?
‎05-03-2019 07:16 AM
Hi you
I have configured as image but when disconnect LAN, WLAN still online. Please guide me to configure it properly.
‎05-02-2019 12:44 PM
