How to replace RADIO WIFI CARD P/N 142571810000A
Tuan_Nguyen1
Hi you
My AP 7161 have problem with wifi card. I remove it to replace but i see 2 card wifi (band 2.4 and band 5ghz) same P/N 142571810000A.
What should i do?
1 ACCEPTED SOLUTION
ckelly
Tuan, none of the Extreme APs are designed to be user-serviceable.
If the AP is out of warranty and you do not have support on it and don't plan on it in the future, then you can attempt something like this at your own risk.
As far as the radio cards, they are both dual-band cards. This is why they both have the same part number. They are interchangeable. If you can locate a replacement card somewhere, it should work.
3 REPLIES 3
ckelly
Here's a GTAC contact page.
Tuan_Nguyen1
Thank you for very useful information. I want to repair AP7161 and AP7562 who to contact?
ckelly
