How to upgrade RFS 4010 controller with new generations of AP?
Tuan_Nguyen1
Hi you
I am using AP 7161, 7562 and controller RFS4010 with license for 16 AP. I plan to add new AP 7562, however supplier informed that new generation AP7562 will have wifi 6 and it cannot be added to RFS4010 controller.
So how should my system be able to upgrade or replace the old APs with newer ones?
I upgraded the Controller for 1.5 years and I reported to my boss that it will add new Aps later on.
1 ACCEPTED SOLUTION
Fritz_Burnell
New Contributor II
WiNG added heterogenous virtual controllers quite a while ago.   The AP460 can be a virtual controller for the following APs: AP460, AP410, AP360, AP310, AP8533, AP8432, AP7662, AP7632, AP7612, AP7562, AP7532, AP7522.
Here is a link to the article:  https://extremeportal.force.com/ExtrArticleDetail?an=000089448
10 REPLIES 10
Christoph_S
Hello Tuan,
The short answer is “yes” the RFS4000 does support the AP7562 with up to the lastest WiNG 5.x firmware.
Thank you,
Chris
Christoph S.
ckelly
To transfer controller licenses (common scenarios would be to replaced a controller that failed and had to be replaced...or a controller model upgrade was needed due to installing more APs than the controller is spec’d for) you simply need to open a case with GTAC. They will assess your license entitlement for your current controllers and be able to provide licenses for the new replacement/upgrade controllers. These license migrations are handled on a case-by-case basis.
zlinuxboy
Contributor
@Chris Kelly what does it mean to transfer your existing licenses from the RFS4010 to the new controller. may I transfer my RFS4010 existed license to vx9000 and activate adoption all the ap?
Tuan_Nguyen1
Hi you
I want to know exactly if the new AP 7562 can be managed with my existing controller RFS4010. @Curtis Brabham  below says that AP7562 is supported by WiNG 5.9.8.2.002R, as is your existing controller.
Curtis_Brabham
New Contributor III
The AP7562 is not WiFi 6.  It’s still 802.11ac wave 2, which is WiFi 5.  Just wanted you to be aware of that before you install them and expect to see 802.11ax.
Additionally, the AP7562 is supported by WiNG 5.9.8.2.002R, as is your existing controller.  You should be able to upgrade the controller and adopt the new AP7562’s that you’ve already purchased.
If you need WiFi 6 you’ll have to step up to the new universal AP’s, which will also mean a new controller.  At that point, you could go with a virtual Extreme Campus Controller.
