Not mesh connection Mesh between AP 8432 and AP7632
Alan_Phan
Dear Team,
Please help me resolve this issue:
I try to setup Mesh between two APs. One is connected with Ethernet (AP 8432)and one not(AP 7632).
. Would you please give me some idea can fix it.
many thanks,
Alan
1 ACCEPTED SOLUTION
Christoph_S
Hello Alan,
Recommended changes:
Change control vlan in meshpoint on both so something like vlan 99
Change antenna mode from 1x1 to 2x2 again on both as an override
Critical change:
Add country code to your rf-domain or else the radios will not broadcast:
rf-domain default
no country-code
use nsight-policy default
If issue is not resolved at this point I would recommend you contact GTAC to open a case.
Thank you,
Chris
Christoph S.
6 REPLIES 6
Alan_Phan
Hello Chris,
Thanks for your information. In this case, I can set AP8432 do controller and mesh connection with AP7632 or not?
Regards,
Alan
Christoph_S
Hello Alan,
I've attached the meshconnex setup instructions. If testing in lab/office make sure you follow these guidelines:
1 - The APs both be running on the latest recommended firmware. In your case this would be 5.9.2.6
2 - Make sure that the APs are a few feet apart
3 - Reduce the radio power to 1. Once tests done and connection established, reconfigure the power to whatever you need it to be prior to deployment
I hope this helps,
Thank you,
Chris
Christoph S.
