4 weeks ago
Hello,
We are working with an RFS6000 running Wing v5.8. The APs are placed in a management VLAN, specifically VLAN 911. The APs are correctly receiving IP addresses from this VLAN.
We have configured the AP7532 profile for this VLAN under Interface > Ethernet Port, as shown in the image below.
The configuration under Interface > Virtual Interfaces is also set according to the second image provided.
Our question is regarding VLAN 1. Is it necessary or trivial to have VLAN 1 configured on the Ethernet Port for proper adoption of the APs? Any insights or recommendations would be greatly appreciated.
4 weeks ago
Hello @Elias_Morais_Pe,
VLAN 1 is important for initial adoption since it's the untagged vlan but if the management and native vlans are anything other than VLAN 1, you can remove it and only use the network MGT/Native vlan IDS.
BR,
